You sure? Because im pretty sure its air going back into the the turbo causing compressor surge or something? Yea mines not adjustable..
It made the same sound but worse when the vacuum line got cut off.. So im positive it was air going back into the turbo.
Maybe your right though
Blendercloud is correct in the BPV bouncing and relieving/trapping pressure, but that pressure wave is applied back to the compressor as well. In most cases of mild bounce(flutter) the turbo doesn't actually have a compressor stall, but it "could" if the backpressure pulse is hard enough. What I prefer to prevent is ALL the BPV bounce/flutter which is what the OEM BPV is designed to do. Mazda knew the effects of poor pressure control and used a very good diaphram design that works extrremely well.
I will pay postage/shipping (US only) for anyone's OEM BPV up to ~5 or so. I need a spare and I'll do some functional verification on them...
