Has anyone figured out a bolt on upgrade for the rear yet....with or with the e-brake???
Even if you can't bolt on the mz6/ms6 rears maybe the rear mz3/ms3 ones will work as via option
Front this thread: Brakes will fit, the E-brake cable won't. Maybe boostdprotegelx have found a solution for this yet?
I for one will not touch the front brakes if I can't do the rear ones.
Wagon: I know you dissagree with me on this, but the rear brakes of the MSP aren't good at all.
(But you got to remember that before the MSP I was used to cars made to europpean ECE specs. I complained about the rear brakes to two different dealers in USA and they both told me they were in spec, one even told me they were in excellent condition. Then I got home and the rear brakes flunked the first inspection here.)
what are you basing this statement on?
Ebrake and rear brakes are completely different... as long as my e brake stops the car from rolling when parked, I could give a damn... if your beef is with the ebrake, its likely improperly adjusted anyway.
lol do you guys really think that a 1 1/2" brake upgrade is going to upset the "brake bias ballance"? Maybe if you had 10" drums in the rear and actually drove the car hard enough to notice.
this is an awesome cheap upgrade.
I hope to do it soon.
thanks for all the great pics and info posted!
Mazda6 setup with 16" GT3
Different Angle wheel spins with no problems
I dont know what the offset of factory ES wheels are, MS6 will not fit 16" wheelsso do you think this would fit with the stock 16" ES wheels then? i have my winter tires mounted to them and i cant afford a new set of wheels and tires
