Am I good to run a DP without a tune? Sorry for the newbie question, but coming from a boxer engine we could not run just a Dp without a tune or EM...just getting my feet wet with the MS3
Mods:
CP-e CAI
SU cold-pipe boost tube
Turbosmart Dual port
Yes. Make sure you have a boost gauge and that you are not exceeding 17.5-18 psi.
That's the point where you may encounter boost creep or where the ECU may slap you back down hard with load cut, depending on the outside temperature and a lot of other obscure factors. The turbo is small and poops out at 6,000 rpm and can't last long at sustained boost levels above 18 psi. The ECU starts closing the throttle plate at 6,000 rpm to protect the turbo from overheating. Max hp and therefore your shift point should be between 5,500 and 5,800 rpm because of this. But the turbo is a good choice for this platform, IMHO, because it is very responsive, has very little boost lag, and represents a good compromise in a car that most use as a daily driver.
The dp, especially a catless one, will raise boost by about 2 psi, which is a good thing. It does put you close to maxing out the wastegate because of the small wastegate port on our turbo (boost creep then ensues for those who have this issue, although it has not affected me). It also does run up against the max load table mapping of the stock ECU which is very aggressive in jumping in to stop the fun.
Finally, IMHO, you should really run your BPV in full recirc on this MAF engine that has already metered and matched fuel to any air that later escapes to atmosphere, making an already rich AFR worse.
Just one opinion based on experience with mods listed below. Others may differ. Catless dp/rp works great with stock BPV and stock tune. 13.4 quarters at 106. 60-100 mph in 6.1-6.4 range depending on temps and humidity, etc, 40-120 in 12.5 seconds. Really crappy 60 ft's. Need driver mod or better tires to fix that.
