I was planning on getting protege sedan headlights since you can get new ones cheaper than p5 headlights. But then I saw some retro installs on the sedan lights and just did not look right. The reason I wanted bigger projectors was simply for the properly sized to look OEM. I think I would stick with the stock p5 headlights, but now you have peaked my interest on whether I should get a 55w setup with battery kit. Could you take a side by side comparison shot? Does the projector come in the low beam configuration? The reason I ask is if I plan on using the stock high beams versus the flip down of the shield and not wanting to wire up an high beam adapter. I do not use the high beams lot, but I think the stock high beam might shoot further.
I am would be doing this mode for looks, safety, and so I can stop replacing the low beams bulbs for an arm and a leg.
