Saskatchewan17
- 2008 TR Mazdaspeed 3
Any updates on the ride Lucas? Still thinking about a new intake manifold and more aggresive cams? Keep us updated.
Stock ecu should be plying the motor with fuel if the air is cold not pulling it out.............
i mean i dont want to have idle issues.. you know.
i dont want to soak the engine in AFR's of 12's on idle to keep the car running you know...
so i might stick with 255... ill see.. i need to find a stock set of cams for now![]()
(eyeballs)and there is nothing i can really use off the shelf, since it wont work. Focus 2.3 block + head are slightly different then mazda..
