Bad flutter
kylefire5
2006 Mazdaspeed 6
I just installed a turbosmart duel port bpv USED and I am new in these things. I have bad flutter what shoul I do?
well does it flutter at full boost? part boost? sounds like you need to back off the spring pressure.
It flutters any time that I here it. At full boost and normal driving. I will back it off. What will happen of I back it off? What incrimment shoul I go in? Thanks for the help!
well you can start by, at idle loosten it up till you can hear it leak just barely, then tighten it down 2 full turns. then make a couple of wot runs and if it still flutters when its super soft, i would check all your boost/vac lines.
sounds like it just needs adjusted. i have the same valve and it took quite a bit of adjusting, and more adjusting to get it just right.
I tried to back it out all the way and it still it fluttered. I then tookl it off and backed it off all the way and the spring came out. With the spring out I cant even depress it with my hand. It is kind of rusty looking. I think it needs rebuilding. Is this somthing I can do?
I put the plastic piece back and took it apart, cleaned it realley well and put it back together with the proper lube. It works great. Just needs a little fine tuning.
Thanks for the advice.
