Mazdanspeed
Like the title states, is there any way of limiting the boost through the use of a boost controller to run, lets say 12 psi instead of 15.6? Just wondering...
the easiest and cheapest way to modify your boost level is recalibrating your right foot.
What if you were to disconnect the Boost Control Solenoid...wouldn't the boost then be controlled by the wastegate alone (~10psi)?
hahaha, ok then, i guess my mpg will have to remain as bad as its always been, lol.
could you wire in a relay switch or something and run it inside the cabin like a simple on or off?
really cant go wrong with driving style
