There is an MSP rear sway at the junkyard for $45, and it comes with the endlinks already. Is there anything else I would need besides new bushings? I'm trying to find Energy Suspension bushings for it.
Since my car is so low I have my endlinks all the way shortened damn near. Should I drop the sway bar under the lower control arm and extend the endlinks? It hits and rattles sometimes
My RSB was resting on the lateral links since my car was so low lol. I got an MSP bar with normal protege sedan endlinks (the longest OEM ones) and it now sits pretty parallel to the ground and below the lateral links.
I got this antenna from an 08 CR-V, it's a little bit larger at the bottom than the base of the antenna, but it's still way better looking than the stock one.
well it wasnt today but last night till one am i took my old body kit off took my door handles out iam goin to shave them, i took my body side moldings off, i started to install my hid conversion kit,
i just got back from my shop.. began pulling my motor. unplugged all the harnesses, and wheels off, axles out, coolant drained etc etc.
i'll be pulling the motor this week.. but i just didn't feel like doing anything else..
about an hour i was up there i did that and pulled apart an entire civic motor/trans for a buddy that blew it up.. he is selling the head/trans etc.
fogs always on. finally.
did u take pix of the install? I hope, cuz I want to do this.
there are pics in the thread, but it's simple. Just find the fog light relay, its' the smallest one behind the dash on the driver's side. There is one red wire coming out of it, cut it and attach a short 8-10" wire to the end coming from the relay. Tape over the other end and pull out the fog light switch. In the foglight switch you have to find the green/black wire and attach your other wire to it. I put connectors on the wire I added and the wire at the fog switch so I could just unplug it if I ever needed to. Like I said simple and took me less time than it did to type this out.
drove her around today as she is my daily. when all of a sudden Both headlights turn off. leaving me with the "fog w/driving lights mod"... but the highs still work. i cant believe they both went out at the exact same time right? electrical idk?
