- 2011 Mustang GT
There are several reasons why people have switched to 5w-40. Most recently is the TSB from Mazda regarding the smoking turbo phenomenon that seems to be more and more common. The MS6's PCV system is inadequate, and for now, this is a temporary fix.
Second, fuel shear in FI engines presents a problem. If you get a chance to look at 5w-30 UOAs for 5k miles or more (which is considered normal oil change interval for the car), you'll see the dilution becomes present over time. 5w-40 does help to block that, and provides adequate lubrication for the length of the oil change.
Last, the UK standard is 5w-30 or 10-40/10w-50 per the owners manual.
People aren't just changing their oil to 5w-40 because it's on a whim, there are documented results and benefits to doing so. One of the minor downsides would be a slight decrease in mileage, but for extra protection for your engine, it's worth the hit.
