Oil filter change and recommended filter cap wrench
So I'm at 69,990 miles today and 100miles from Service (oil) reminder. So I got a gallon of 0W-20 Pennzoil (US$23 at wally mart) and used my wonderfully helpful neighbor's garage and ramps. I had a new 6-pack of OEM filters for my 2017 CX-5 and really should have let the car cool down but boy that oil came out hot and fast into the oil drain pan.
I took off my filter 1WPY with a trusty cap wrench that fit for the last few years, cleaned the area and got a new filter out and realized it was not the OEM 1WPY-14-302... that I normally had but the new OEM one is a PE01-14-302B. It is wider than the 1WPY and my cap wrench won't fit. Not so much a problem now, as I only hand tighten to put on.
But thinking ahead to the next 3-4K mile change, I need a different cap wrench. I looked and searched and all the results were that of Mazda owners asking what wrench but answers were not helpful...at all. However, typing this the Already Discussed ? had some useful info and I'll just clarify that there are DIFFERENT sized cap wrenches and Mazda OEM filters.
I don't have a metric rule so I can only guess the 1WPY is 63.5-64mm wide? Where the PE01 is 65-67mm wide? I did find a cheap 65-67mm 14-side cap wrench for US$8 and hope that is correct. I don't have a set and will also get some filter pliers/wrench because ... some things you need to remove and won't by hand alone. I don't want the ratcheting 3-wing kind since you have to hold that, and the strap kind doesn't allow for tight spaces. I also think I may drill a hole in the cap to allow poking out a stuck filter since they get oil on them and not easily extracted from the cap.
Finally to add that since my last change, I used 5W-20 for the Summer and I lost THREE mpg with same range, same driving load. Tires are all inflated correctly. Recent air filter. Not changed gas type (reg vs prem). I'm hoping its true that 0W is better and OEM recommended in the Mazda manual. Might also get some Liqui Moly additive (if you have a suggested site where to get for discount...lmk).
My neighbor was impressed that the Mazda had the filter and drain all in easy access vs his Ford and wife's GMC.
I always tighten the oil filter by hand. They stay put and come off with reasonable efforts especially if you lubed the rubber gasket before putting it on.
LM moly treatment is available on Amazon for about $9. Can it be cheaper elsewhere?
Would you be interested in replacing the drain plug with a drain valve?
Upvote 0
Slip-joint pliers (like Channel Lock) are a pretty reliable fallback option if you don’t have the correct size of end cap wrench. It’s a little awkward getting them up to the oil filter on a SkyActiv four-cylinder, but I just had to do it two weeks ago, and I managed reasonably well.
I endorse the idea of replacing your drain plug with a valve. I’ve had a Fumoto F106S on my CX-5 for five years, and it’s very easy and convenient. It fits above the aero cover, and the lever is protected but still easy to access.
Upvote 0
I have been using a strap wrench from Kobalt. Even tightening just to spec (3/4 turn after the gasket makes contact) it can't be undone by hand after a few thousand miles. You need something to get it started.
I see you're using 0W-20 which tells me non-turbo. The OEM filter would be 1WPE; 1WPY is for the Turbo. Anyway, they are the same filter media and shell. They are indeed smaller than the OEM from Hiroshima. I took a picture of mine at my first oil change:
The PE01-14-302B filter that you cite is likely the "value line" filter. I have not seen one in person.
I thought about getting something like https://www.amazon.com (commissions earned) but since the strap wrench has been "good enough" (fiddly as it is) I haven't bothered. Also, before too long I'll be transitioning to changing the filter only every other change, making investment in tools even less worth it. The only thing I'll have to do is drain from the valve, close the valve, fill up with new, measure the level, and I'm done.
Upvote 0
The OP might consider visiting an auto parts store with the intended filter and purchase a decent Lisle brand cup wrench. The cheap Walmart dual size (ex: 65-67) are lighter gauge metal and don't grip the filter as deep and slip. Also, Lisle makes an expandable wrench to grip hard to remove filters. It digs in and will chew up the filter but grips well. Choose the appropriate size range as thee is more than one. I have one in reserve as a last chance, "save my butt" tool.
Upvote 0
I didn't think 5w20 would make a difference in the summer? Same viscosity.
Trying to understand why everyone is using a wrench to loosen/tighten the oil filter. Is it due to limited clearance? When you have the car on ramps, do you get your head and upper torso under the front end or do you work from the side?
Upvote 0
Leverage. It is too tight to undo by hand.
Upvote 0
This. Even when I’m removing a filter that I installed and I know had oil on the gasket and wasn’t over-tightened, it still takes more than I can manage, even after cleaning the filter and wearing a grippy rubber glove.
Upvote 0
Maybe a piece of sandpaper would help, although I haven't had any trouble other than when I did the first oil change and had to remove the factory installed filter.
Upvote 0
Like I said a few replies ago, it happens even when tightening to spec by hand. After it has some miles on it, it gets tighter. That's why I need a strap wrench to get my filters off, that I put on only 4000 miles ago.
This. I only hand tighten, and I still have to use a wrench to get them off. It is what it is.
Upvote 0
Sorry I missed that part. The filter comes off usually in the first hour after the car is stopped and the new one goes on soon after. After I tighten it to the point of no more turns, I loosen it by about a 1/4 turn. With the 7K/8K-mile OCI, taking it off was easy. Only once did I find leaks around the filter because I did a poor job. Luckily it wasn't enough to leave a drip on the plastic cover. You folks have it on much tighter than I can. 👍 Do you all lube the gasket fully or just the side that meets the mating surface?
Upvote 0
The thing is, if I go snug plus a quarter turn on installation, I can back it off easily with just bare hands. A few thousand miles later, I can usually get it off by wiping it clean and using textured nitrile gloves, but I still have the wrench or slip-joint pliers handy, just in case.
Upvote 0
With the Mazda filters I'm using, the instructions are 3/4 turn after the gasket makes contact. I just note where the lettering is, then turn it 270°.
Upvote 0
this ^^^
and the non MV filter comes with lube but I usually put extra :) old school tricks.
The Thailand filter comes with some grease on the top side. My habit from maintaining the R56 is to take the gasket off and rub clean oil all over it. On that car the rubber o-ring goes onto the filter cradle and into a groove after the threads. The filter itself is just the naked media with top and bottom caps.
With the spin-on type of filters, I pry/pull the gasket out before pouring fresh oil in, and I spill some into the groove/channel that the gasket sits. The gasket goes back in and fully immersed in oil. The residual is wiped clean of course. Totally unnecessary, maybe. 😂
Upvote 0
I may need an oil filter wrench after all. Trying to cut open my most recent used filter and have zero grip on the metal body. 🤦 The strap wrench that I do have is for an old Suburban and much too wide.
Edit: Added that $12 tool to my cart and thought that's almost the price of an OEM filter. Decided to try something else. I wrapped a strip of silicone self fusing tape around the metal body and got a good grip with my bare hand. I also repositioned the cutter to cut into a different point.
The OP didn't ask for all this... 😂
Upvote 0
