So I recently installed a DEFI Imperial 60MM Boost Gauge and DEFI Controller in my vent. I have a few questions....
1. Does it look like I`m leaking boost?
2. I get that all the readings on the boost gauge above 0 is boost pressure, but what are the readings below 0? (The opposite of boost would be vacuum right?)
3. I`ve seen as low as 10 psi on some 1st, 2nd, 3rd, and 4th gear pulls and have seen them as high as 19 psi. Is that range normal?
4. What causes such variations in boost pressure?
5. What should a typical mazdaspeed 3 be boosting?
6. What will give me more consistent boost pressure? (Aftermarket BPV i.e. HKS SSQ or an AP or both)
Please analyze these vids and tell me what you think (All pulls were done with traction control off, stock bypass valve, CP-E CAI and TIP, CP-E RMM, Engals ETD)
First recording: http://www.youtube.com/watch?v=fF4FlXoGYA0
This is 2nd, 3rd, and 4th gear pulls.
Second recording: http://www.youtube.com/watch?v=SZCkWzF1-FU
This is 1st, 2nd, and 3rd gear pulls.
Third recording: http://www.youtube.com/watch?v=pOlRzd8A7KA
Fourth recording: http://www.youtube.com/watch?v=AQNanI_B97U
This is the highest boost level I`ve reached since the gauge was installed.
Thanks guys!!
P.S. Sorry for the side ways videos
Thanks guys!!
