Loud screeching noise
bubba019
Mazdaspeed Protege
I've been getting this loud screeching noise coming from the engine every few times I start the car. I just changed my belts. What the hell could it be?
(squinty)
what belts did u get changed? and if because they were just changed they are usually put on a bit looser because the belts will stretch just go back and get them tighted up a bit thats all i had the same problem.
you shouldn't work on a car if you don't know what you're doing.. they should deflect about an inch when properly tightened.
I've been getting a screech lately too on cold start ups. It's not the engine, it only makes the noise when I roll. I personally think its the brakes, cuz when I get on the brakes and they warm up and get the pad to rotor contact going it goes away, usually after one step on the pedal.
Im getting it on some random start ups and not when im moving
just happens when theres a bit of water on the belt id say dont worry about it unless it is doing it all the time
