- 2007 Mazdaspeed 6 GT Retired: 2002 Protege 5
So i did a search to see if there was a thread about different oil filters you can use with the spin on oil filter conversion kit. So anybody know what oil filters i can use?
Is there a particular vehicle that you can cross-reference from to get appropriate filters from? I'd be interested in a Wix filter if I did this.
the ones that i know of that fit are
K&N --- HP-1002
Fram --- PH3614, DG3614, PH7575, PH966B
Purolator --- L10028, L10241
im sure there are more out there..but those are only the ones i know.
yeah, the filter conversion comes with a genuine mazda filter.
whats wrong with just using a mazda brand filter?
I used K&N HP-2009 for a while. Switched to amsoil Eo-15 filter. Same filter size just different make. I think that is the largest filter you can put on. I may be wrong. Ive heard of someone using a wix filter that is slightly larger than this.
will these filters fit the prosport sandwich plate adapter? i'd assume they have the same thread but dont know for sure.
I pay like 12 bucks for it. I have an amsoil dealer 10 minutes from my house. And im a member so I buy at cost.
I get the ea0 33 since that's what the cross reference said was for the mazda oem included filter to wix to amsoil guide said. I also have a sandwich plate adapter with sensors installed (haven't installed the gauges yet) and I have no clearance issues. The 15 is probably overkill if it costs more and is taller since you're probably not going to leave it in for the 25K miles. If you have a speed, you should also be using 0w-30 not 5w-40. Getting a thicker oil to prevent smoking is only masking your pcv issue and you should get the fix rather than cause higher oil temperatures and pressures that will restrict oil flow and prevent proper lubrication.
For the record I have a 6i and run 0W-20 and the EAO-33 filter and have for the past 20K miles with no issues and my dealer even likes that I do.
