Well, everything was going good, until I got high-pitched gear whine that wasn't affected by shifting or the throttle....basically came on at 30 mph, then got loudest at 65-75 mph. I looked around the threads, and figured it was the rear diff...tech called this afternoon, he's localized it to the front diff, which will be replaced under warranty. After that, they will check the rest to make sure the sounds are gone.
I was simply wondering, is this a common replacement/repair item on the MS6? And if it is, has everyone had it done? I know about the turbos, power windows, etc. just wondering about the weak points in the driveline, and what can be done to prevent this failure in the future. Thanks for anything you can come up with.
