Camber kits question
ONRAILS
06 Mazdaspeed 6
I have Megan Springs on my MS6 and the tires wore 10 times worse on the inner 2 inches of the tires. Is there a good camber kit that I can purchase that will alleviate this problem? Can you purchase a rear kit only, or should you buy both front and rear? Any of you have a kit installed on your car?
Thanks,
Front or rear?
Front camber requires new ball joints,and SPC makes adjustable ones for about $180 per set.
For the rear, the camber is adjustable via the inner eccentric bolts on the lower control arms.
how much can be adjusted on the rear though? Like in my case for example, if you recall that pic I posted.
Specifically, I'm not sure. I know the alignment specs are pretty generous in the rear, so I would imagine around +-2 degrees. That's purely an estimate though.
How's your negative camber after lowering Steve?
I'm about -2.5 on both rear wheels right now. I need to get the alignment checked after my rsb install since I had the rear springs out, and I'm going to request that it be dialed down to -1.5 on each rear wheel.
