Thanks for the pics! I will be heading to mess with my car tomo. Tonight we are celebrating my birthday. Hopefully I got a cell phone, ha. My current one broke after i slipped in the oil spill the other day so I can't use my 8 button, and I have to do some funky things on my cell to find the right word to say. ha.
Tomorrow's duties on car:
-My bro said there is a slight oil leak that looks like it's coming from the middle of the motor. might be coming from the oil return fitting welded on. he said he didn't think the guy did that well of a job.
-Put more coolant in b/c it's low
-check my install of vac block to see if it's on correct side of check valve.
-Fix gauges
-Make sure all IC clamps are secured tightly, as well as vacuum hoses to rule out vacuum leak.
-Anything else guys and girls?
EDIT:
-Once everything fixed and car running well, i'll install AWR side motor mounts.
-Fix new fans. They are Hayden fans. For some reason I don't think their coming on, so i'm going to connect them to battery to see if they work in general. I have two of them, and I turned the AC on to see if the one would come on and it did not.
