2010 Buick LaCrosse gets Fuel Efficient Ecotec 2.4L Four-Cylinder Engine
mikeyb
Contributor
01 BMW 325xi Touring
<script type="text/javascript" src="http://edge.quantserve.com/quant.js"></script><script type="text/javascript">var tcdacmd="dt";var ANBCH="10";</script><script type="text/javascript" src="http://an.tacoda.net/an/12030/slf.js"></script><script type="text/javascript">var sr_adspace_id=8290507; var sr_adspace_width=1; var sr_adspace_height=1; var sr_ad_new_window=true; var sr_adspace_type="graphic";</script><script type="text/javascript" src="http://ad.afy11.net/srad.js?azId=8290507"></script><script src="http://ad.afy11.net/ad?asId=8290507&sd=2x1x1&ct=15&enc=1&sf=0&sfd=0&ynw=0&anw=1&rand=2075750&rk1=46351692&rk2=1245934824.29&pt=0"></script> <!-- Start Quantcast tag --> <script type="text/javascript"> _qoptions={ qacct:"p-15hwQa2jgxkJ6" }; </script> <script type="text/javascript" src="http://edge.quantserve.com/quant.js"></script> <noscript>
</noscript> <!-- End Quantcast tag -->
<noscript> </noscript> <!-- END Burst Network CODE -->
Buick has announced they will be adding the 2.4-liter four-cylinder Ecotec engine to the upcoming 2010 LaCrosse.
Engineered to provide a balanced mix of fuel efficiency and performance, the direct-injected 2.4-liter Ecotec boasts 182 horsepower (136 kW) and 172 lb-ft (233 Nm) of torque. More importantly, the engine is expected to return 20 mpg city and 30 mpg highway. For comparison, the LaCrosse's 255 hp 3.0-liter V6 and 280 hp 3.6-liter V6 average an estimated 17 mpg city and 27 mpg highway.
According to GM's vice chairman of Global Product Development, Tom Stephens, "Direct injection is a key component of GM's ongoing strategy to use advanced propulsion technology to help us deliver more fuel-efficient cars today and in the future."
Look for the 2.4-liter Buick LaCrosse to be offered "later this year" with a base price slightly below the 3.0-liter LaCrosse's MSRP of $27,085.
Looks kinda like the 2010 Camrys
The interiour looks like a wood grain spaceship, but I like the HUD.
That thing will be a dog in a car that size. No thanks. I'd take either V6 option and trade a small mpg penalty for the car actually moving when I hit the gas pedal.
0-60 in....NEVAR!!!!!!
I think the turbo'd ecotec would have been a better choice or Buick should bump the HP up to 200hp just to be competitive with every other midsizer 4 banger on the market.
Downsize the engine, slap a turbo on it and call it GMboost and squeeze 32-34mpg outta it with 200hp and you'll be golden :P
also...this is no worse than BMW and MB researcing Geo Metro-esque 3pots
It makes no sense that they would not use the ecotec turbo motor. None at all.
sure it does, you have to remember, it's not General motors anymore..it's Government Motors...they know best!!!
Bunch of idiots :/ sigh
Only way it would make sense is if that thing had all sorts of weight reduction done to it. Anyone know how much this thing weighs?
2010 Camry LE
Curb Weight: 3307 lbs
Base Engine Size: 2.4 liters
Horsepower: 169 hp
19.56 lbs per hp
LaCrosse is 18.65 lbs per hp at 3395 lbs.
They've got the Camry beat, it's got available AWD and is MUCH better looking.
2010 Camry LE
Horsepower: 169 hp
19.56 lbs per hp
Pretty much everything looks better than the camry :P lol
That being said, Buick is more in line with lexus here mate...
Se let's compare to the Lexus Camry err i mean IS250
2.5L V6 204hp/185ftlb
weight- 3651lbs
lb/hp = 17.9
So it's even pretty close to that... and is only down 13ftlb of torque over the IS...
as a side note:
IS350-
3.5L V6
306hp/277ftlb
Weight: 3527lbs
lb/hp = 11.53 0.o
BMW 328iX AWD-
3.0L V6
230hp/200ftlb
Weight: 3627lb
lb/hp - 15.77
anyone think this is NOT going to sell?
americans don't like 4 bangers, especially the buick demographic
people who buy buicks are old farts with money anyway... you think they can't afford the V6 engine and the gas?
another one of those poorly executed ideas GM... bravo!
2009 V6 Buick LaCrosse = 3495lbs
so +/- a couple hundred pounds
Oh that's not nearly as bad as I thought it would be. I thought it would way over 4,000 pounds! That I4 will create sufficient pull. Not a bad remodel honestly, I would just go with the Malibu if I were in the market for a family sedan.
