I originally posted this on Mnmazda, but I have kinda hit a wall in diagnosing this so your feedback is welcome.
Last week I upgraded my inlet and added a boost gauge. Everything ran well on Saturday and Sunday. Yesterday I take the car out in the morning and it runs fine. I go out in the afternoon , everything is fine on the way to lunch. On the way home while getting on the highway, I accelerated down the ramp (15PSI boost) clutch to shift and it sounds like I have a turkey in my engine, then the BPV makes it's mario coin sound. This continues every time I boost more than 5 or so PSI.
I come home, and change the spring in the BPV (was blue with no shim, so I swap to yellow with no shim) and no more turkey sound but, it wont hold very much boost.
Today it surges again and i check all the hoses I can without removing the battery box. AFAICT all the hoses are on and in good condition. The hose coming off the BPV (the big one) is on but is easy to slide off with out moving the clamp. I also saw that the tube going to the boost gauge solenoid is pinch so I freed it up. Rev the engine and BPV works fine a low boost, go out and test drive, anytime i get above 5PSI it gobbles, then the the BPV *chings*
So I am thinking that the BPV isn't operating fast enough, which could be remedied by using the softer yellow spring, but then it won't hold the proper amount of boost.
So far I have tried all spring and shim combos, and swapped with a known good Forge BPV. I also upgraded the clamps on the BPV and inlet.
Here is a video I made of what it sounds like. Any feedback is welcome. http://tinyurl.com/n2tmr3
