- '13 CWP MS3 & '16 Mazda6 GT
nothings worse than trying to break free the allen bolt on the front brakes to replace the pad by holding the allen key and smacking it w/ a rubber mallet only to hit your finger and tear off a nice flap of skin....
pics or it didn't happen
I'll settle for the story at least...
IIRC, it's orange. Lemme check the wiring diagram. I hunted this down for some reason awhile back........
OK, wrong, not orange. I found panel light control switch with output going to audio illumination with LG/B which should be light green/black & then output going to climate control with W/L which should be white/blue. Then of course, a seperate black for ground. LG/B also looks like it heads to instrument cluster on the schematic. Were you asking for illumination of the a/f gauge or a pwr wire to run the gauge?
installed a Mazda 6 wagon rear wiper arm...
soooo... u can work on some eyelids?
oh, and i took the rear seats out of mine.
haha for you and TwisFM, I promise to work on the eyelids tomorrow. I just got done with finals yesterday. On my to-do list for tomorrow is shipping out the Mazda t-shirt to racerxgirl, eyelids, finding the last of the fittings I need for the turbo install and ummm that's about it. Sunday I'm installing the AWR rear mount if I can get the bolts to budge (a nice 3 foot steel pipe on the end of the breaker bar should give me more than enough torque as well as plenty of the trusty PB blaster). I'm also going to remove the header and install the turbo manifold with the turbo and S-pipe and measure out the new downpipe that I'm having made which oughta be a blast. Pics to come for sure.....
