Depends where your mounting it. A pillar you can get power from the dimmer switch plug. If in the column you can get it around the iginition or stalk plugs, and if near the radio you can grab the radio power.
do you know what color the power wire is in the dimmer switch?
^^^... couldnt find anything helpfull... evryones just like you tap an acces wire.... i dont have a tester :(... i should get one..
Alright so the turbo install is not going to be done this upcoming week. I decided not to rush it and wait til after summer quarter. :(
I really need to get some more stuff done like buying a new oil pan and tapping it, getting some fittings and random little s***. Oh well, at least now I can take a break before the next quarter starts.
istalled the 40 dollar special autozone fogs.....they be bright.....plus i have all working lights now......pics come tomorrow....does anyone make a h3 bulb in yellow??
IIRC, it's orange. Lemme check the wiring diagram. I hunted this down for some reason awhile back........
OK, wrong, not orange. I found panel light control switch with output going to audio illumination with LG/B which should be light green/black & then output going to climate control with W/L which should be white/blue. Then of course, a seperate black for ground. LG/B also looks like it heads to instrument cluster on the schematic. Were you asking for illumination of the a/f gauge or a pwr wire to run the gauge?
soooo... u can work on some eyelids?
oh, and i took the rear seats out of mine.
slow... she bit me today! scraped my knuckle when undoing the seat. i still have to figure out where to put the monster fuse holder. it just doesnt want to fit anywhere.
