mazdaspeeeeed
- MSP 2003.5
I have read just about every thread on the topic and tried everything i know of to fix this damn thing.
here is the list
-replaced EGR with brand new one
-replaced waste gate with a forge
-replaced ALL vacuum lines
-checked all connections on all pipes and tightend things down
-replaced spark plugs
-replaced primary 02 sensor
-replaced MAF sensor
-replaced cracked manifold with a new stocker
-installed FMIC with all 2.5" pipes and relocated MAF. all pipes are very secure and no leaks.
im out of ideas... the car used to have a real bad rough idle but that has been fixed now. the only thing in notice with the car now is on full throttle it will buck a little bit. occasionally the rpms will drop slightly and then come back up to normal....
I have reset the battery by disconneting the negative and pumping the brakes but the code keeps coming back...
here is the list
