- MSP 1145
i got my fingers crossed for ya!
hah. thanks man!
I ask because I have a midpipe at my house that I need to install but I need to extend the 02 sensor wires as well. I just thought some dumbass put it on the wrong end of the pipe.
Edit: Would you suggest just buyign one of those pnp 02 sensor wire extentions?
is the car sitting low at idle too? And I think your the MSP with like 20k on it right? If thats the case, you should be more than fine on the injector and belt front, but it never hurts to inspect. I would def. inspect the MAF and BPV to make sure everything is tight and flowing smoothly. You can also pick up MAF sensor cleaner at Pep Boys for under $10
...and I hear ya on the high temps, I would be the one to break my A/C a week before this random April heat wave...haha
It can because when the diaphragm tears it leaks vaccume. Doesn't always show on a vac gauge though.(uhm)
Well I'll have to do some serious checking this weekend. I'd like to get a second opinion, but can't get anyone in the Tampa area to take her for a spin to help me diagnose it. Wouldn't be that big of an issue if it weren't my daily driver....I'd just tear it apart until I found the problem, then put it back together. Just trying to pinpoint the problem because I don't have the time to tear it apart.
I may have to get new shocks for the rear so is it cheaper to replace all four and not just two? Never bough shocks before (usually total car before they go bad) Also what is a good brand that will give me the same performance as stock, not lower the car too much, and not cost an assload.
buy a set of replacement Tokico HPs....
http://cgi.ebay.com/TOKICO-HP-Shocks-struts-Mazda-Protege-99-03_W0QQitemZ370138347987QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item370138347987&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
http://cgi.ebay.com/TOKICO-HP-Shock...s=66:2|65:15|39:1|240:1318|301:1|293:1|294:50
Sell the MSP then.
