Me too... nothing but grins when I added the BCs... though I guess the GT Spec rear setup is out of the picture now, glad to know before I spent much time researching it.
I wouldnt rule it out. There is a speed shop by my house that can get custom arp bolts and studs. all i have to do is get an extended stud for the top hat. It just sounds like the studs arent long enough to go through the shock tower and gt spec tower bar. Mine shipped today, i will run them by the shop and see it he can get longer studs for the top hat when i get them
This is what I was thinking/hoping. I haven't seen the BCs in person so I don't know if the studs can be removed.
interesting, let us know what you find out....
Will do..
Also here is what ups had dropped off..
sorry for the crappy iPhone pics. DIdnt want to drag out the slr..
washed the p5 and stowed in a garage....working on clay barring the whole thing than another bath than a good wax in a day or 2
Man...you should of told me you got a Perrin fuel rail...I have one sitting in the garage to never be used...not sure why I haven't sold it yet...
So on the BC gt spec compatibility, one of the other members, o.g.sk8er has the same setup and it works for him, so IDK.
I got the popping/rattling sound fixed, loose front endlink. Also got her an alignment, but passenger rear wheel has a bunch of camber they could not fix
you might need to rotate the top hat 180 degree
in the rear? Then it just wouldn't fit... something else is up. Aren't the rear lower mounts slotted to gain you some camber? Make sure it's all the way out.
not sure, its been a while since i messed with the rear. i just remember on the front if you change the position of the top had you can gain more camber. justin b, xelderx would know better
