Fuses no, and I can still roll the windows down from the passenger sidedid you check ALL of your fuses? Did you try rolling them down from the passenger side?
probably just out of power window fluid.
there is a tread about this all you need to do it go to each door and from the top roll the window down a little bit then roll it up holding up the button for a few moments and you will hear/feel ma few clicks in the doors and that recalibrates the automatic windows... you will need to do this everytime you disconnect the battery
