lol what temp did you get? did you get the high/lo kit? I didnt think it was needed so I saved the $25 lol
finally spaced out my wheels today...much better. 16mm spacers for the fronts bring the total offset from a +42 to a +26 and the rim sits flush with the fender.
before:
after:
justin are your fenders rolled? I may end up doing the same thing as you and get the 16mm spacers to get a +29 offset.
EDIT: also, do you have extended lug bolts?
looks good justin.. you should pick up a set of evo5s:)
jp your car looks sick on those.
haha thanks man.
yep, i rolled my fenders today. the 16mm's are bolt on spacers so they come with the extended lugs.
thanks dude!
man thats looks sick... I'd be afraid of ramming that wheel into the fender...
and what suspension os that? I want to lower the MSO about that low, but I dont want an angled wheel...
where did you get your spacers from? Also, did you use a fender roller or did you baseball bat it?
i work at a shop, we have an fender roller at the shop. just make sure you heat up the paint before you roll so you don't crack it!
i'm on full k-sport kontrol pro coilovers.
5k bi-xenon, i almost never use the high beams but i got them incase someone decides to start inspections. Its like having a fallout shelter in your basement.. sure youll prolly never use it, but if the commies drop the nukes ill be ready.
ah, thats why you paid so much, the bi-xenon. Mine are just low beam 35w 5k w/ the slim ballasts...but $85 shipped is the cheapest I've seen these go for via any vendors either way lol...
the hi/low kit was an extra $25 but that was just for a hallogen hi....lame
