Thrust Bearing Clearance/Failure Is The ANSWER
FORZDA 1
`07 Speed6 Sport
Hey Watson, I've got it! What do you have Sir? I have THE reason for essentially all the "random" engine failures. The key bit of info is the clutch pulsing. This ALSO explains why the BSD seems to have a longevity effect on the engine. Mazda has/had a problem with the thrust bearing clearances in their early series of 1.8 liter engines in the Miata. No BS in those motors, but the SAME type catastrophic engine failures resulting from excessive crankshaft end-play.
Ok, here's my theory and rationale:
The main culprit in these failures is the crankshaft thrust bearing. The thrust bearing is loaded heavily in the DISI turbo MZR from the BS angle-cut drive gears AND the HD clutch required to hold 280 lbft of torque against the AWD system and 3500 lb car. As such the thrust bearing wears, allowing excessive crankshaft end play and resulting side loads on the HEAVILY stressed connecting rods. A bit too much thrust bearing wear = too much side load on the con rod and Zoom, Zoom, BOOM, rod (pick one) and/or piston collapses from the off-center load and there you have it. Explains everything! Even why some new cars GO and some BLOW for no "apparent" reason.
I say EVERYONE concerned about their engine should check the crankshaft end-play per the FSM and see what they have. I don't have the reference right now, but it is a few thousandths of an inch. It COULD be another series of engines have the "incorrect" thrust bearing clearances at initial assembly.
ALL the failed engines to date can be checked for this clearance before the crankshaft is removed. I would wager that Mazda Japan already knows about this! The Miata crowd is very diverse and pursued their engine failures up through MNAO and got results. I should have checked mine when I had the pan off recently, but wasn't even thinking about it. I'll be checking it real soon though. It can be checked externally without removing the pan.
I also recommend jumpering the clutch switch so you can start the car WITHOUT pushing in the clutch. I have ALL my manual trans cars jumpered....
Great info, I'm definitely going to have to look into this. I know that keeping your foot on the clutch a lot while driving can significantly reduce the life if these bearings. Mazda might know a bit about this already, it even states in the car manual, not to keep the clutch pressed in for long during stops. Which seems pretty much like common sense with any car.
Why would this be important, I guessing no pressure on the bearings during start up? I prefer this just for a convenience sake, but if it will increase the longevity of my motor, I'll do it.
Starting the car with a high load clutch puts a lot more wear on the thrust face of the bearing before the oil is moving. You can install a simple interlock switch "jumper" for the clutch. Look under your dash and you will see yours at the top of the clutch pedal mechanism. Just insert a short piece of paperclip into the back of the two-wire connector to connect the pins. Leave the plug connected.
All done, quick and simple. Oh, and don't forget to take it out of gear to start the car!
Ive been thinking about this for a while, could you take a by any chance of the jumper location? thanks.
Here's a photo of my car with jumper installed...
I posted that and then saw it over on 6club, thanks. Curious to see what the reaction will be over on MSF.
i cant open the pciture :(
Yeah, sorry. I don't have the original file with me so I tried to import it. It worked, but it is too small to see clearly. I'll repost the original later, or you can pop over to 6Club to see it....
