TOTALLY off topic, but don't you feel weird enforcing a rule you don't understand?
tis off topic...but police officers enforce rules they don't understand all the time... its in the rules - and enforcing said rules comes with the blue writing dude.
guys i've just edited 2 posts for su references - please don't do it...its not permitted and you all know it..cheers.
Yah well im assuming that the 3S-GTE rods are a viable option. If so then the rod ratio gets bumped up to around 1.63.
If mah maths is correct that should bring it within 9,000 rpm region as B18Cs have a similiar rod ratio.
Or cheaper alternative would be SR20 Rods which would be around 1.58, which is just a bit more then installshields rod ratio IIRC.
EDIT: LW 3SGTE rods in a FP what compression would that be? (Is there an equation?)
12 or 13 compression in our climate is pretty crazy LW.
I realise theres more to it then piston acceleration however i found the new rod ratios to be pretty good. In regards to your build idea thatd be pretty expensive because as far as i know the 1.8 and 2 litre engines have differences relating to the way the cranks hooked up? However adapting k series rods wouldnt be cheap either.
Personally for a nice build SR20 rods would fit the bill and might be a bit easier to work in then 3SGTE rods. 1.58 rod ratio isnt to bad, installshield got to 8k on similiar rod ratio so in that regard MPS shouldnt be too much of an issue. recipricating mass however i failed to consider.
btw i found a formula for working out static compression i believe however i have nfi as to the unswept volume of a cylinder.
