spark plugs
Gonna thread jack just a little bit here. Does anyone know what the stock plugs on the MS3 are? I've searched the boards and some people say Denso and some people say NGK.
mine said FoMoCo when i took mine out.. ford motor company.. dont kno if that helps at all.
Feel like throwing a "how to" down?
mainly cover the problems encountered pullin the IC
think we've all changed a plug before.
THANKS!!!
Seriously?
1. Park car.
2. Shut off engine
3. Open hood and secure with prop.
4. Remove the 2 ten milli. bolts securing shield.
5. Push shield toward rear of car and lift.
6. Remove 3 nuts retaining tmic.
7. Loosen clamps on both the hot and cold boost tubes.
8. Disconnect BPV hose and vac. line
9. Remove TMIC
10. Remove connectors from the coils
11. Remove the 10 mm bolt retaining the coils.
12. Look in the hole, BAMM there it is. Also a good time to do the coil stretch mod.
Seriously?
1. Park car.
2. Shut off engine
9. Remove TMIC
Coil Stretch mod??? whats this if you don't mind me asking?....
Seriously?
1. Park car.
2. Shut off engine
9. Remove TMIC
11. Remove the 8 mm bolt retaining the coils.
Fixed, but seriously its just as easy as that.
i have heard of the coil stretch mod in the past but im also wondering if there are any upgraded coil packs for the car that would help? like i know the VW's are a hole nother story but the shop my friend goes to put STI coil packs in his 1.8t cause they were better then his stockers...anyway just curiouse if there is something like that for our engines?
Wow, seriously, like with my rolla, man , dude, ya , like, just pull on plug boots, and sorta bam like put this , socket thing on em and dude you just twist it, ya know? and they like unthread, and stuff like that(help)(help)(help)(help)(help)(help)(help)(crazy)(crazy)(crazy)(crazy)(crazy)
