- Purchase a lower grill insert replacement
- Purchase DG grill
-Remove the vertical tabs from backside of insert and carefully clean up goobers from where it was attached. Take your time with the clean up and use a new/sharp razor. (I removed the tabs w/ a dremel tool)
- Lay grill upside down (on towel) and set the grill in proper place so that everything is lined up and equally linear
- Using a silver sharpie, make alignment marks on the insert and grill once everything is lined up. The markings will help you keep the grill in the right place. Remember your working from the backside and don't have a front view to check for alignment. These markings will save you....trust me
- Once the two are aligned cut the excess of grill away....basically you're just cutting the insert into the shape of the grill
- Now you need to EPOXY the HELL out of it! Be creative and get into all the crooks, crannys and crevices that needs epoxy.
- Follow the directions on the epoxy for drying time before installation.
Voila! Now you have a beautiful and custom DG grill.
Waiting for these guys to get here to help with the motor install...supposed to be here in 30 minutes...
Ahhhhhhh....hahhhhahahhahhahaaaaa...
what motor?
that motor?
Installed my 5000k HIDs (8000k was ridiculous) And right now im waiting for the primer to dry so i can finish up my rear valance. (its been months since ive wanted to do this)
Ok Finished up the Valance with some flat black. Hmm idk what else i wanna do today. I think i might put in my grill insert on my DG grill.
Idk i asked a local forum here on hawaii about them and everyone was like "its so rice" or "you dont even get enough light" i dont know it was irritating. Oh also its illegal here in Hawaii.
6000k is blueish and 5000k from what i noticed is super white. BTW added my grill insert its getting painted right now. will post pics once its done.
