that car looks nice...my 2 cents.
1) Here is a wheel/setup that COBB runs and is do-able. why re-invent the wheel.
Volk RE30 18”x8.5”, +52mm offset Wheels (Street Class)
Toyo R1R 255/35-18 Tires (Street Class)
Prodrive GC05 18”x 8”, +46 mm offset (Mod Class)
Toyo R888 245/40-18 Tires (Mod Class)
you can wrap the wheels in whatever.
2) I really think you should get a braille battery to save weight and a carbon fibre hood.
3) if possible, go for BBK, rotora comes to mind. no stud replacements required and no spacers required if you pick the right wheels. This will allow you to do the following:
- swap out pads quickly at the track
- less brake fade
- saved un-sprung weight on the front axle. at least 30 lbs if i remember correctly.
4) Short throw shifter
do everything you can to save weight, including removing rear seats when going to track. etc...
You are tracking and competing..and will have to commit in some form
Also, a few folks use this: Motive bleeder to bleed brakes and is a quick job.
Euro 0100 model
http://store.motiveproducts.com/sha...reType=BtoC&Count1=688015162&Count2=605155587
thanks and g'luck.
