I need a front Bumper Grille!!
I will call around but the cheapest I found online was $175.00. Take some pics of it soon love this car!!!!
Just need the Grille
I've got one I pulled off my MSP... however the mounting tabs in the corners are broken off. if I ever put it back on I was planning on using a zip tie in the top of the center reinforcement bar... yours for a minimal charge.
I will take it if you think it is still usable and wont just hang around loose.
We have front license plates in Texas, and the bumper-mounted plate was making it difficult to replace the grill. (The license plate frame is right in front of the lower/bumper grille, blocking it.) I couldn't remove the license plate frame because the last time I did that the nuts behind the bumper fascia fell down and I couldn't put the plate back on without removing the bumper. After many attempts, I realized I could just pull the bottom of the license plate frame forward, flexing the bumper slightly, but causing no damage. I was then able to slip the lower grille in from below. I never took off the bumper as others here have said is necessary. Note that my P5 has always been garaged day and night, so all the soft parts on it are still flexible.
As for how I removed the old, broken grille, I couldn't figure out how to do that nicely. I ended up compressing the locking tabs as much as I could, then finally resorted to ripping the damn thing out. It broke the tabs in the (broken) grille, but not the corresponding slots in the bumper fascia. So no problem upon installing the new grille.
I have never understood why some people don't like zombie threads. Especially with zombies being more popular than ever..
