I think I have decided to get the HKS valve. But I am concerned about the fitment.
Initially I wanted the MS3 specific valve so there would be no messing with the oring. But after seeing this thread:
http://www.msprotege.com/forum/showthread.php?t=123729755&highlight=ssqv
It seems that the return tube needs modification. I was looking for a BOV that could be easily removed and returned to stock if I needed to go back the dealer. Does the mazda specific kit allow you to "spin" the valve to get the best angle or is it non adjustable?
Would I still have the same kinking issue if I went with the standard oring kit?
Does the standard oring kit also have an issue with hitting the intercooler shrould?
Cost is not a concern just looking for the easiest installation without having to do permanant modifications.
So which kit should I choose?
Also looking at this kit:
http://www.dabears2k.com/product_info.php?cPath=39_63&products_id=140
Comes assembled for $25. But is there any mods to the return tube required? Or interference with the intercooler shroud?
Thanks
Thanks
