H3br3w_Ham3r
- 2008 Mazdaspeed3
Which would you go for? Protege garage has some from Goodridge and Corksport but if you have another kind that you prefer I'm all ears.
I was planning on buy from PG so if the products are equal it comes down to price.The goodridge and CS pieces both work quite well. F2 also has a set. I would go for the CS units mainly because I have never had problem with their customer service.
I'm not worried about looks here. I intend to auto-x and track my car so I was gona get the brake lines and some better pads to help keep my right foot in check.i've had the goodridge lines on my last car. they worked but eventually began to look like crap. all the stainless/braided lines will probably give you the same results. go for something that looks good! preferably something coated. like the autoexe ones. just dont pay that damn much!
I could think of something better to spend my money on TBH. Done this mod on my last 2 cars and they really did next to nothing. That and the fact that the MS3 brakes as well as brake pedal feel are pretty darn good to begin with. I would go with whatever is cheapest here.
+1, though I'd recommend stainless steel brake lines for even a DD. They aren't going to give you horsies or make you stop quicker, that's not the point. The point is that under hard braking conditions (track days, autocross, spirited driving), your brake fluid will boil and trap air bubbles when the rubber lines expand from the heat. This causes your brakes to feel like mush and severely hamper your car's ability to stop. Stainless lines and frequent bleeding will make sure your car's best safety device is in tip-top shape.I dont think you are supposed to feel the difference when driving on normal conditions.
The point of of having better lines is to not feel any difference. After several laps of aggresive braking, the braided lines will keep the pedal feeling hard, while a factory line will start to get mushy, therefore creating that soft feel on the pedal.
I guess it all depends on what you plan to do with the car. So trackdays, HPDE, then yes, get em! Daily driving? Better off getting some better gripping pads.
I was planning getting better pads and rotors too but I wanted an opinion on the brake linesSeriously, the last thing you really need to upgrade are the brake lines. I'm not saying they're utterly useless but even in a road race setting, brake fade is the enemy and the order in which you should alleviate that is by bigger rotors, better brake fluid, and to get better braking, higher friction pads. And as a DD, as someone already mentioned, SS lines are pretty much pointless.
Not saying the OP doesn't need them as he intends to track the car but just want the other 95% of the ppl to know that SS lines aren't all that useful and there are other (more beneficial) ways to improve the stock brakes.
What are the benefits of upgrading to a big brake kit (Rotora or Brembo)?
Will them reduce the stopping distance?
