Did some various maintainence today; cleaned up some lines here and there. I've got some pretty decent oil leaks at the turbo oil return line (both ends) and what looks to be a little leak at the oil pan drain plug. Coolant appears to be leaking through the turbo coolant return and from the drai plug of the CS radiator. I also found what my wheels were rubbing against during extreme left or right turns. I guess my alignment is so out-of-whack that the wheels just barely rub the inner fender liner. I also noticed the tread is starting to separate from the front, driver's side tire - looks like I'll need to rotate them as I really don't have the time/money for new tires. Oh well, another fun day with the P5... Nothing that can' be fixed.
