im going with the same wheels and I have the same springs as you, yes it will fit and 235/40/18 is recommended tire size.
any local wheel shop or wheeldude. You can use up to a 5mm spacer on the factory stud and be okwhere can I get a 5mm spacer and how easy is it to install? I see some with new studs and some without. i would prefer without but am not sure if my factory studs are long enough to accommodate a 5mm spacer.
im almost 100%, there is a member on the SU forum that has a +48 wheel with a 5mm spacer w/ no issues. leaving them at +43. I specifically asked this person because they have 3-4 different sets of wheels and i was inquiring as to what works best. I value there opinion, if that means anything, plus there car is gorgeous
EDIT: I see your in south florida, so is the person im speaking of. maybe you can contact them for local reference on this topic
Yes. A 215/45 tire should only go on a rim that's 7-8" wide. Putting it on a 8.5" wide wheel would be pushing it.So would the stock MS3 tires still fit on the rota torques 18x8 +48 offset with H&R springs without any rubbing or problems?? Sorry had to ask!
