And at this PSI I would have to assume you are on the GT25 Stocker...that little detail makes a big difference.Right now with my broken DP, I'm running 14.7 psi on stock injector's on a SS AFC Supermap...
It haul's ball's but,I would not recomend that you run that much boost lol!!!
I ran 11-12 psi for about 2 years with no problems prior to this also......I can't recall what the stock injector max out at but, at 11-12 psi AFR's were alway's below 10.00 the lowest the AEM WB will see.
Hope this help's good luck!
These are just approx. numbers, but for a 4cyl id say the limit would be:
440cc~~180-220whp
550/565cc~~~280-300whp
650cc~~~350whp
750cc to 1000cc~~ between 450 and 550 hp
Unfortunately I dont buy your Scaling at all....COnsiring the stockers are what.....290cc....on an MSP that is 170HP stock...and plenty have gotten 220+ out of them easy....then the next step is the WRX 440cc's.
Not too many people need much more than that on these cars unless heavily built...But hey....your the injector expert.
I thought the same.. seems like the 440s would allow for more than that.
