COBB & Hotchkis rear sway bars
As far as bushings are concerned, COBB bar comes with Energy Suspension bushings. I assume it is the case with Hotchkis as well.
I have my COBB on the stiffest setting and the car has a tendency to fishtail on wet roads in tight turns. But for some reason I couldn't successfully use the bar in the softest setting - something was hitting sopmething on the bumps like it was loose, but I couldn't figure it out. When I switched to the stiffest setting it went away.
I have a Hotchkis RSB "On FedEx vehicle for delivery" (hurry the hell up FedEx). I will post comparison pics between it and the stocker once I receive and being installing it.
I just installed the Hotchkis RSB, it sure is a nice feeling of having an upgraded rear sway. Now I need to get new tires.
are you lowered on anything? i was kinda leaning towards sways or short shifter for my next mod. i was leaning towards cobbs but the hotchkis looks too good. good write up/comparo
Comparison shots:
(ughdance)
I did not. It didn't come with any collars and the instructions didn't mention collars. Can I reuse the stock collars?
Edit: Looks like I can't reuse the stock collars :( Does anyone know where I can acquire some collars for this RSB? What's the worst that can happen if I run without them for a while? Will my turbo start smoking and my wife divorce me?
Edit 2: I ordered some collars from some clamping place I read about in Subaru forums. In the mean time, I'm using 35 cent hose clamps from VATO-ZONE to keep the bar from walking. I hope they don't scratch the bar up too much...
collars?
i just installed my sways yesterday, fun s***.
much better than a down pipe.
The Cobb doesn't use collars. It has a welded flange on each side that is positioned to fit tightly against the bushing, as was pointed out in the well written first post.
I'm starting to wonder if I should have just gotten the Cobb... Oh well, collars are on the way.
Is it normal for the RSB to increase noise from the back of the car? I definitely hear a lot more from the rear when I go over big bumps and crappy roads. I can live with it as long as it's normal. It's starting to feel more like my P5 did stock :)
Collars should only be needed if that bushing is "slippery", meaning it can rotate and move around on the bar. Hence the collar is needed to hold it in place. Some sta bars utilize "grippy" bushings that cannot move from their original location. If the Hotchkiss bar has the latter you won't need collars.
The bar shouldn't make any more noise unless something's loose, maybe the endlinks gave way?
Oh lawd I hope not. I really think it's just noise from added stiffness but I'll get under the car soon and take a look.
The bushings on the Hotchkis are definitely not designed to be used with no collars. The guy who sold it to me forgot to send the collars :\ And Hotchkis seems to have two different manuals for two different sway bar designs. I got the manual for the bar with the rings that doesn't require collars.
The guy sent out the collars when I alerted him to the problem. I had already ordered my own collars at that point though.
Edit: What does it mean when endlinks "give way"?
Sorry, that's not really the right wording I guess, since the links themselves don't fail. I just meant the common issue of the endlink-to-bar fastener losing torque and making a clank/clunk noise. What kinds of noises is it making now?
Hmm... it's hard to describe. It's not a squeak. It's not a metallic crunch or ping. It's more like a sturdy WHOMP WHOMP sound when going over significant bumps or rough roads at speed. It doesn't necessarily even sound like a bad sound. It sounds like my stock Protege5 did with its ridiculously stiff suspension.
I can torque them endlink bolts down harder. I wasn't sure how extreme to get with those so I just tightened them up hard and gave them an extra 1/4 turn or so.
