I was installing my custom turbo inlet today and needed to put on some new vac line tubing (skinny tubing) that goes from this little plastic part to the nipple on the inlet. I pulled off the crimpers and then I wanted to pull this line off, and for ****'s sake this damn thing just didnt want to budge, so i yanked and it broke the plastic nipple it connects to. I haven't re-connected the vac line or anything and wanted to know:
What is the purpose of this particular line, will I be ok if I simply cap it, or is it necessary to reconnect the vac line.
here is a pic of this:
it connects to the little vac part on the top of the inlet (the gold piece on the inlet):
So let me know if I can simply cap that broken hole and cap the one on the inlet, or if I will have to connect vac line to it. If I need to connect it, I will simply break off the little corner of the plastic thing I broke and slip the vac line over it and put the crimper on it, so it won't leak.
What does this thing do exactly? looke lik eit takes a small portion of the air from the intake and pulls it into this sensor next to another vac line coming off what looks like a wastegate or selenoid and there is an electrical plus/possible sensor there??? not sure if thats something the car HAS to read and needs to be connect or it gets a bad reading? if anyone knows please help me out!!!
