LED's
I am telling you I have put 194s in license plate. They have single or 4 led. Buy 2. 1 for each one. Comes in different colors too.
yea the sylvania replacement chart thing? im familiar with it..
i do believe it says my plate light is 1157 or something along those lines
how ever there is no such 1157 led.
there is 194 and there are a couple on www.superbrightleds.com that go WHP-x-x that look like theyll fit. but no confirmation... i think 194 is the route ill go. just hopin some1 will say "hey yes 194 will fit into our plate lights"
(mswerd)
Yes, you can use 194 led bulbs in your license plate light. They're used in your map lights as well! So far, I've changed out my map, dome, rear cargo, and license plate light to superwhite leds. I'm very satisfied! Generally, from what ive noticed, leds dont have as good as light output as standard halogen bulbs, but do provide a more "updated and unique color distinction" to your ride.
sweet
exactly what im going for.
Be careful don't put powerful LED for the license plate light, it can look funny if too bright.
Also, you can't see s*** on the map if you use LED for map light, but they do look very cool.
but why do u need map lights if the p5's got its own integrated GPS Navi system?
womenz needing to do makeup in the car? I know that is the reason Callie wants brighter map lights. We gots GPS, so it si not needed for reading maps
it's hard to get led map lights because the maps make the led face the wrong way.
I use a 5 led 194 in the maps so it works ok nothing compare to what I did for the dome. 36led array.
Pics of the led array?
here ya go
how much that cost ya? I have seen the setup from Oznium for $25 that doestn't ened all that cutting
Gotcha. The Ozinium setup is a flat panel LED, so it doesn't stick down as low.
