- 2017 SG Ford Focus RS -- 2003 Protege 5 -- 2016 Ford Expedition
Stock radio can be a b**** to pull. you need to get 2 pair of the stereo puller wires (you can get them from Wal-Mart for $3. Some people are successful with using coat-hanger wire instead.
you need to pop the black plastic cover pieces off of the sides of the stereo. Just use a thin knife and gently pry them right out.
Then you just stick in the pullers into the holes, and you have to squeeze them inwards, while pulling out.
good luck
I practiced on my buddy's ES before pulling mine... after the first time it gets easier.. Watch anything sharp around the plastic bezel (the plastic carbon fake-ber) it scratches easily.
I used 4 small screwdrivers (jewelers) and slowly worked mine out the first time, the second and third times I used two 6 inch segments of coathanger wire bent in two u shapes. You just need to un-clip some clips on the sides of the stock headunit. I hope i helped, I'd show you how if you came to Alaska...
