builthatch
i can't speak regarding 08.5+, but 07 and 08...if you have a re-q, do yourself a favor and turn off the bass enhancement. there is a switch on the req that says "before amp, after amp, off"
evidently, the signal (high level of course, hence the re-q or LOC) is very flat and healthy coming from the Bose HU. i love the re-q even here because of the SSF and add'l gain controls and LPX-over, but after extensive tuning using the enhancement switch will overdrive the low portions of the signal. you can get ALOT more without it, because w/o it you can run closer to nominal amp gain.
