SeR_Cyclops
 - Mazdaspeed Protege
you CAN change WGA with out removing the turbo.
yea, but its a b**** to get the c-clip off with it on the turbo, even with as small of hands as I have lol
and its nearly impossible to get the c-clip back on without at least unbolting the turbo and pulling it away from the head >.<
it can be done, it's just annoying and almost easier to remove it (at least for me, I can pull the turbo assembly in an hour and a half now lol)
what I did to my msp today: removed the oil pump to send off to docB...then spent the rest of the day crunching numbers and researching the optimal turbocharger for my application...whoo! 25 psi here I come =P
Yep, and unfortunately more money. Not to mention I really don't want to have to remove the turbo again![]()
you can't take off the WGA with a 1/4" socket set without removing the turbo?
On another bad note, I randomly tested my wastegate actuator and sure enough - it's shot. Now, its vacuum source is right off the turbo so a leak there wouldn't cause a problem. It does suck however because the ATP wastegate actuator is only 1 year old and it's already dead. This would explain why I randomly hit 14 psi a while back. Damn...
my atp lasted a few months, but i got it used. forge works great!
I cheated when I did my WGA install. I removed the J-pipe, unbolted the mani from the head, and loosed that bracket bolt from under the car thats by the s-pipe. Then let the turbo and exhuast mani lean towards the rad a bit and reached in and replaced that little clip. Also I would just go purchase new clips becuae im 99% sure everyone will lose that little bastard.
yea, thats exactally what I recommend to get the job done...a little more work involved, but youll probably save yourself a lot of headache and possibly time (ironically)
and yea, those little c-clip bastards suck lol
	looks good bro!
gah I can't decide, buy a second protege and put off finishing this one until I can save up the cash I need....or just deal without a car at all....the later isn't as easy as it sounds where I live >.<
...i have a spare...trade for one of your manis? hahahahahaha!
I don't think I'll ever get rid of the turkey. I just had a HKS SSQV welded in and I still get a little turkey at low boost levels. It's using the brake booster as its vacuum source too. It probably has to do with the 8 miles of other vacuum lines I have under the hood.
always been told to tighten it enough to where you can twist the belt only +/- 90 degrees either way
Well I just went down and checked just about every vacuum line. The BOV holds vacuum as do all other vacuum lines I could check. I can't find any leaks and I can't imagine anything else has seriously changed since last week when everything was working just fine. The only thing I haven't checked is the exhaust but I'll do that tomorrow morning before I leave.
Sweet Deal! unless its a thunder cause im already dealing with that lol
I have a thoery on why our internal gates go bad so fast. The diaphram inside the gate is meant to measure boost, but i think because we tap them off the mani, they see vac, so that diaphram is constanly getting forces from both sides. I think this causes premature wear. I know quite a few oem turbo cars use the turbos compressor housing for a boost reference. This way the WG only sees boost like it was designed for. I tapped my turbo and am still testing this but i cant really say for sure but its not an unfounded idea. it makes sense mechanically.
i thought you meant your intake mani
