Woohaa, lots of posts to reply to.
what about fuel pressure regulators? how would they suffice with NA?
I don't know if you'd NEED one NA...having never put a pressure gauge on a standard one to see how well it holds up under high NA output - but there are certain benefits to getting one. Upping the fuel pressure gives you a little more head room in the injectors. Injectors are quoted at a specific capacity at a specific pressure. If you increase the pressure you increase the amount of fuel they flow (to a point). According to my favorite fuel injector online calculator, the formula for working out the impact of increasing pressure is:
sqrt(Pn/Po)*Fo = Fn
where Pn is the new pressure, Po is the old pressure, Fo is the old flow rate, and Fn is the new flow rate. So, assuming 280cc/min @ 43.5psi, an increase to 50psi will give you an injector flow of 300cc/min. Of course, you need to consider the maximum rated pressure for the injector as well as how much additional pressure in the fuel system the pump will deal with before you get cavitation (or potentially damage to the pump).
The benefit of upping the pressure will
only be felt if you have control over your fuel delivery (piggy back AFC or a stand alone management system) - see my next point for details
Another benefit to increasing the fuel pressure is improved fuel atomization .
My guess would be that for relatively low power, the ability to turn down the fuel pressure would result in less fuel being delivered- which would lean out the mixture and thus making more power. I know this worked on the last car I had (Saturn SC).
Once you start adding up parts and increasing the air flow, you'll probably need to re-add the fuel you took out and possibly add in more.
The problem with tinkering with fuel pressure on the standard EMS is that you are talking about fairly small changes - changes that are well within the stock computer's ability to learn around. It is likely that the ecu will simply learn around your fuel pressure trick, and put you back to square one.
wouldnt really help. fuel management units are designed when boost pressure goes up, fuel pressure will go up accordingly.
a regular adjustable fuel pressure regulator wouldnt really help you either since only adjustments are to be made in certain areas. a engine management unit is much more useful and acutally benificial.
There are 2 types of fuel pressure regulators i know of - Rising Rate, and 1:1 ratio boost ref regulators. a rising rate will increase pressure by a ratio (say 2, or 3:1) for every psi of increased manifold pressure. A 1:1 will give you 1 psi more fuel pressure for every psi increase in manifold pressure. The standard fuel regulator is a 1:1 type (and really, thats all you should be ever using. huge high power import drag cars use 1:1.... mind you they are using 1:1's that flow insane amounts of fuel - I have a Sard standard adjustable 1:1 ratio fuel reg in my car).
Remember, that whilst an NA engine may not be "boosting" pressure is going to change from around 25"hg to 0"hg from idle to wide open throttle/max load. So the increase in fuel pressure in line with an increase in engine load is a requirement of an NA motor just as much as it is a boosted engine. Whether spending $100 on an adjustable regulator for an NA car is required or not is a different story - but a reg of some sort is required, otherwise the fuel pressure will be pegged at the spring pressure of the reg, and as the engine begins consuming greater amounts of fuel as load goes up, and revs rise, you could start running very low fuel pressures, and max the injectors very quickly.
just needed an easy way to increase fuel... without piggyback... so do the top feed injectors from a wrx work? if so ill get those and maybe the AEM F/IC or SSAFC
See my second point... a reg for you wont do anything. Also going to big 440cc injectors is a bad idea, because that is a HUGE jump in capacity. The stock ecu wont be able to get around those injectors - it will run at minimum duty and even then it'll be too rich.
the ECU pulses the injectors for a given number of milliseconds, dependent on fuel delivery requirements for a specific rpm vs load map point (at its most simplest - of course there are other fuel corrections and so forth...but theres no need to go into that for the sake of this explaination). lets say that the ecu's minimum pulse is equivilant to 5% of duty. 5% of 280cc is a stack less than 5% of 440cc... quite simply, if you are not changing your ecu - DO NOT CHANGE your injectors....forgetting the fact that the stock injectors are going to be more than enough for anything you are ever likely to do NA, and that you can get a spot more head room later on with an adjustable fuel pressure regulator - putting 440's in an NA FSDE running pump gas is, in a word STUPID (if you were running methanol you'd want 800cc/min injectors but thats because methanol's going to require 4x as much fuel to achieve a desirable Air Fuel Ratio - basically if you are not going to be converting to alcohol, or some other exotic fuel there is ZERO need to buy bigger injectors)
yea that would work fine, but why do you want 440 cc injectors. the stock 280cc injectors are fine for NA set ups.
They sure are! in fact, 280cc injectors at a maximum of 80% duty will quite happily support around 190 crank horsepower at 43.5psi fuel pressure. If you want to live on the wild side and bump the maximum duty to something around say, 90% (which would be fine, for short bursts at maximum injector usage) - you can get 210 to 215 crank horsepower out of them... push the fuel pressure up to around where mine's running these days, about 55psi at wide open throttle, you can produce 240 crank horse power. Now, if you were going to have a tilt at 100whp per 1000cc's, you'd probably look at 330cc injectors just to keep everything a little less on the edge... but only if you had a stand alone (which you would if you were chasing these kind of numbers). Quite simply - if you're not touching the ECU, don't bother touching the injectors. If you are not intending on making astronomical NA power (or intend on using some sort of crazy alcohol based race fuel), don't bother touching the injectors.
BinoMP5 - I'm not trying to have a go at you here - i'm just pointing out that your injector fetish is a little bit silly and you're better off spending money else where. Put the money towards a stand alone. Once you've got a stand alone, go get a sard regulator - chances are thats all you'll
ever need to touch on your fuel system. I have a sard in my car and i'm very happy with it (i bought it because my stock regulator was damaged when pulling the manifold off a while ago....so i needed a regulator and thought i'd buy something nice - really though if i never broke the stock reg, i probably never would have swapped it out!)
