phantom6294
Folks -- Still relatively new to the forums, the MS3, and the Mazda community as a whole (I've had my MS3 since July 1st). I got a DashHawk yesterday as my birthday present from my wife. I've read several threads debating the effect of heatsoak and how quickly the engine bay and the intercooler would become heat soaked and how quickly they would shed that heat once the car is moving again. So, since my wife is gone for the weekend, figured I would do some driving (that can't ever be a bad thing in a MS3!) and some data logging. This is just my attempt to contribute to the community. If I made some glaring errors, by all means, please speak up -- I certainly want to present accurate information so we can have a useful discussion and come to meaningful conclusions.
So, my tools were:
- 2008.5 MS3 GT Stock
- DashHawk v2 (v2.5 Final software/firmware)
- One lead foot
- Some premium gas
- Lots of patience to sit still in a MS3 for 12+ minutes
What I logged:
- Act AFR (not displayed on graph)
- IAT --> Pre Turbo Air Temp (right?)
- Boost Air Temp --> Post Turbo/Post Intercooler Air Temp (right?)
- Vehicle Speed
- Boost / Vacuum
*Note: It appears that the 'Ambient Air Temp' sensor in the DashHawk is the same as IAT and as such, was not used/logged -- Ambient Air Temp was being reported as 80F during idle on the dash and dropped to 79F shortly after starting to move
My method:
- Drove around on the interstate with some (safe) boosted runs to get the engine/engine bay/turbo heated up (About 16 Miles / 20 Minutes total before coming to idle of which 14 miles were interstate)
- Started logging about 1 minute before coming to a stop
- Parked the car, turned off the A/C, and let it idle
- My plan was to idle until IAT and Boosted Air Temps leveled off *OR* the DashHawk reached 65% of its memory capacity for the log ***I ended up reaching 65% before it seemed like the temps leveled off
- Quickly (but safely) returned to highway speeds
- Monitor how long it took for IAT and Boosted Air Temp to return to pre-idle temps
So, here is a break down of the data, followed by three screen shots in the data logger on my PC; 1) leading up to idle, 2) idle period, and 3) post-idle period. Times are given referenced to the start time of data logging.
- Ambient Temp 80F/79F
- Pre-Idle IAT: 86F
- Pre-Idle Boost Air Temp: 115F
- Start time of Idle: ~115 Seconds (1 Minute 55 Seconds)
- End time of Idle: ~870 Seconds (14 Minutes 30 Seconds)
- Total time of Idle: 12 Minutes 25 Seconds
- IAT / Boost Air Temp 1 Minute after complete stop: 93F / 131F
- IAT / Boost Air Temp 2 Minutes after complete stop: 98F / 137F
- IAT / Boost Air Temp 3 Minutes after complete stop: 102F / 144F
- IAT / Boost Air Temp 5 Minutes after complete stop: 109F / 150F
- Maximum recorded IAT: 143F
- Maximum recorded Boost Air Temp: 187F
- IAT / Boost Air Temp once vehicle at 40MPH (Time: 890 Seconds, ~2 Minutes after moving): 123F / 173F
- IAT / Boost Air Temp once vehicle at 70MPH (Time: 927 Seconds, ~3 Minutes after moving): 109F / 154F
- IAT / Boost Air Temp 1 minute after continuous movement: 107F / 152F
- IAT / Boost Air Temp 2 Minutes after continuous movement: 96F / 138F
- IAT / Boost Air Temp 3 Minutes after continuous movement: 89F / 129F
- Time when pre-idle IAT (86F) was reached: ~1115 Seconds (~4 Minutes after moving again)
- Time when pre-idle Boost Air Temp (115F) was reached: Did not reach pre-idle temps --> lowest Boost Air Temp post-idle was 125F
Graphs:
Note: The colors of the graph lines DO NOT COMPLETELY MATCH the axis values. Since IAT (yellow graph line) and Boost Air Temperature (blue graph line) use the same temp scale, they are both using the yellow axis scale. Vehicle Speed (magenta graph line) is using the blueaxis scale, and Boost (cyan graph line) is using the magenta axis scale. Yes, I know it is very confusing. Sorry, I was focused on the post, not making the graph pretty.
Also, I realize they are large (dimension-wise) but I hope to make them easily readable so people don't have to take my word on the values.
Conclusions:
I guess I should say first that this is just one set of data and is by no means conclusive. I think though it is a good start and some basic conclusions can be drawn from the data I have so far. Also, 12 minutes is a long time to be idle in every day driving. I did this mostly to get idea if/when the temps would reach a maximum point; they did not. As such, one might argue that the engine bay and/or the intercooler were not yet 'heat soaked' as they were still heating up. I'm not a physics expert though...
I decided to let others make their own conclusions or let the conclusions be reached during discussions. So, talk amongst yourselves!!!
Random Observations:
I found that when you get into a boosted situation, the Boost Air Temp takes a sudden dive in temps (should be visible in graph screen shots). I hit about 5PSI and the temps dropped from 130F to 110F but then the Boost Air Temp returned to just shy of 130F once off boost. This seems counter-intuitive to me -- boosted air should be hotter than non-boosted air. My only guess would be that where ever the Boost Air Temp is being read is being affected by a heat soak condition and the air is actually cooler than is being recorded. Once the boost and higher air flow comes on, the higher flow rate over the sensor cools it off??? I dunno...
Future Test(s)?:
Obviously a 12+ minute idle time is a LONG time to sit idle for every day driving -- a 12+ minute stop light would be killer! It would be interesting to see if the temps come back to normal proportionally quicker if the engine bay and intercooler aren't as 'heat soaked.' For example, 1 minute of idle takes 15 seconds to cool, 2 minutes takes 45 seconds to cool, 3 minutes takes 1.5 minutes, etc. I would also like to do some much longer interstate runs (30+ minutes minimum, preferably 1+ hour) to see how the temps do at highway cruise speeds.) On the flip side, I'd like to see how the temps drop with lower cruising speeds -- such as <50 M.P.H., in both continuous driving and after a 'heat soak' condition. Another interesting test might be to get the car hot (give it a quick turbo cool down) then shut it off and let it sit for varying amounts of time and see what the temps look like when the car is started back up.
I have no plans to get a FMIC, but it would be interesting to compare too similar cars (sans the intercoolers) and see the differences between TMIC and FMIC in heat soak conditions, cruising speeds, etc.
So, my tools were:
- One lead foot
- Some premium gas
What I logged:
- Vehicle Speed
- Boost / Vacuum
My method:
- Pre-Idle IAT: 86F
Graphs:
Conclusions:
Future Test(s)?:
