RallyeRedSi
- 2008 Civic Si
how much did they give ya
Since some asshole hit my car 4,000
Cancelled the order on the 5Zigen wheels. Getting some different ones. (thumb)
No..I bet a Cat could do that....Serious restriction.
Welll..it would cause a loss of power....Now the Los of PSI....It could..but Only if your TUrbo is MASSIVE and it just never gets enough time to spool up.
I know you have a big one..but I dont think its big enough to have that problem.
Ok..SO let me get this right..After you put the cat on...and had the problem...You then(now) removed the cat and it runs normal again?
I knwo a hi flow cat can cause a loss in power but i dont see it causing a loss in psi
and those wheels would be???
Dare I do it. Yes.....I'm goin' murdered out!
Yeah, but the car feels like something is holding it from going and producing more power, plus my turbo is really laggy now, that sucker needs to go over 4.5 K to boost, and feels weak.. it got to be the cat, i bet TBK welded the bung in the wrong side and direction of the cat and that s*** is backwards..
