another problem.... bad bogging under boost
dinicola999
2003.5 MSP Dark Silver
drove on vacation, 4hour trip to NJ, car ran fine on the way down, after few days of not driving, car would start up fine, no rough idle, soon as i put my foot down and hit about 4-5 PSI car would bog out and buck, i just drove it back home 4 hours and it would run great untill it was under heavy boost, it would just not go, previous owner had Unichp Installed and had car tuned, i can swich the car between 2 different maps, ive tried both and neither seem to help, i just replaced valve cover gasket, temp censor, and the plugs are a month old, the idle vac pressure is around 22-23, the car has 2 or 3 hairline cracks in header (new one on the way) and she still burns a little oil (blue out the tail pipe) waiting to get my crank vents installed, just tryin to make this car run smooth...
had the same problem....never even thought that it could be my plugs and wires. just replaced all plugs and wires and car runs PERFECT!!!! But of course....just my opinion.
what i did was i went to Advanced Auto and i bought NGK plugs the gap was pre-set i asked them if i had to gap the plugs and they told me not to touch them, but how could it be the plugs if the car has been running fine for a month or so on the new plugs
my mass air flow is right after my air filter, i also have 3 codes
P0131-O2 sensor 1
P0140-O2 sensor 2
P0171-system too lean
my buddy also suggested that there may have been an elevation change between here and right next to the coast in NJ, so my air/fuel may have been all messed up
My car does exactly the same, good idle, no apparent issue until boost condition. My car is stock except for a K&N drop in air filter (yeah.....it is stock), I am afraid the oil from the K&N has fouled part of the MAF sensor (found some on the edge of the MAF). I will try cleaning my MAF tonight and share the results.
Cleaned my MAF (really easy stuff, takes 10 minutes). Car seems to pull more. I need to test it under normal condition (traffic, heat, etc) and I'll be able to tell if this solve the bogging problem. But you should do it anyway, costs like $8 and it's done in no time
doin it today, heres a pic of location of my MAF
My car is doing the same thing, but no CEL. I had a CEL previously and codes revealed several problems with MAF. Used some MAF cleaner and CEL went away....but not the problem. Still bogging and bucking under full boost. I figured maybe it was a leak, but its holding boost just fine. Then figured maybe something with the coils, wires or plugs, but the car idles fine all the time; whether its a cold start, an hour of driving, or all day of stop and go driving. So makes me think its gotta be something else. I took the A/F gauge out because it was some cheapo and wasn't working anyway. I've checked my vacuum lines and they look fine, plus its reading between 18-20 at idle which from what I've read is good right? I'm at a loss. Any ideas what it could be?
my car is also Bogging like ^^^^^. i checked the Code this weekend. got P0171-Bank 1 too lean.
i cleared it out, but it came back......
BTW, the car is BONE stock with 44k on it. (the Block, head and clutch have 11k on them)<<<<all replaced under warranty.
Seriously guys....I had the same EXACT problem for miles!!! car ran great at normal throttle, idled perfect...held boost...but under boost bogged bad!!! Cleaned the MAF...no CEL...changed my wires and plugs out and car runs like brand new!!! Went NGK's site and bought both wires and plugs!!
I had this same problem bought a new MAF still didnt fix the problem but it was in the winter months ive found out that our cars just cant handle boost in the cold the air is too cold for the sensor or something crazy but as soon as it warmed up outside my car ran fine
have not had the time to do that yet.......
did you also have a Cel code??
i have the P0107 lean bank 1 cel
I've been told now that even with good idle, one of the coils or wires could be on the way out, or just misfiring under boost. Ordered new coils and wires, so I'll let you guys know what happens. If its not that, then I'm thinking maybe my MAF is going bad and not reading the correct mixture and leaning it out.
Well I guess lucky for me, I'm in Tampa, FL so I don't have to worry about the cold air. But anyway, I just put in the new coils and wow...HUGE difference. So if you're still having this problem, try replacing the coils. And they aren't too expensive either. I paid $40 at autozone for both.
