(wrc)
Well..I finally am starting to make minimal progress after many..Many setbacks.
I am going to go through and post some pictures of whats been done so far..parts I have aquired...and where I am heading.
I hope to have this car done by The end of July...Period. (screwy)
It all started here...With this....Piss poor shape for an 03....Has a ding or dent in every panel....and a Blown motor due to oil starvation.
After buying...I started my plans and Began Collecting parts.....a LOT Of parts.
Then I borrowed a Hoist From Merlin3 (local Member on another Forum) and Out the motor came.
Such a tiny little thing it is...This is Tranny and all. Fully asembled motor.
The motor Was stripped down and prepped for a Rebuild.
The motor was Sent to Ohio Georges where it was to get Forged Oliver Long Rods, .020'' over CP Pistons 8.5:1 (low comp.),ARP main Studs, ARP Rod Bolts, New oil squirters , Bearings, Thrust washers and Balanced.
The Crank Was scored a bit..so it needed polished....But nothing That George couldn't handle.
The head was Sent to Dave Layer @ Heads up Performance in Beavercreek for a 3 angle Valve job, New seals and some portwork.
While those were out...I decided to go ahead and start getting some of the powdercoating done on Engine parts.
Sent my Valve Cover off for polishing...for the Custom Red Candy powdercoat it was to receive.
Heres the polish
Heres the Candy Powdercoat...Which almost looks like a red Chrome.
SO while the engine was out...The car is pushed outside...where it sits...and get pummeled with snow....Friggin' Ohio.
Then the motor came back from Ohio Georges....After a lot of Tedious little machine work..He got the Custom Rod and Piston Setup together , clearanced and Balanced.
Unfortunatley....George doesn't like painting anything..sO I had to give it a once over when I got it home.
Here is where we ran into clearance problems with the the pistons and Rods....ANd then there was the Oil squirters..but we wont go there.
While the Engine was away ..I continued to gather parts...From my forums mainly..But Chris at Precision has Gotten me anything I couldn't find there pretty much.
These guys rock..and I can't say it enough.
I had aquired a Mazdaspped LSD to install into my factory Open DIff P5 tranny....and then...lady luck fell into my lap.
I scored an Original OEM NEW Mazdaspeed tranny...For less than what I could sell my original parts for...Cha-ching!
But I still have to take it apart and Weld the LSD inside of it for strength..THey are know to Break the RIng gears off at even Stock Power levels.....Let alone what I plan on throwing at this thing.But when welded up..they are Extremely reliable and a good LSD as well.
Over the next couple of cold months..not much happened...Picked up parts as I found them....Did tiny little things and Wheeled and dealed as much as possible to get what I needed.
I still dont have everything...But man I am getting very close.
ForceFed said:Originally posted 6-7-08
Heres the polish
