stock airbox question
wisniaPl
whre this should go
I assume you're reinstalling the stock intake?
You see the arrow pointing down on the stock airbox just left of that clip? The clip goes just above that arrow.
There is a plastic "post" directly behind that arrow, as I recall. The nylon "clip" slides or clips over that post. I've only had mine off a month or so, and I've already forgotten. Pics are on my PC at home.
I'll pull the pics when I get home and also look at the airbox itself. That should jog my memory.
Push the rubber piece with the arrow on it torwards the headlight and you will see a little notch where the nylon clip goes.
These should help:
That should do it or better yet that clip as with the rest of the air box should go in your basement or storage area after you replaces it with a CAI or SRI
