Ok....I have the Spec Stage 3+ Cluthch that will be going in the Pro...Quite aggressive if you ask me.
Now....Here is the Dilemma.
I have a Fidanza Flywheel....7lb'er That I was planning on putting in....But I am not sure If I really want to do that.
Yet I hate to run the Stocker...Which is an Unknown weight....I will however be weighing it tonight.
The Aluminum will rev very fast....But on the FLip side....WIll Also Slow the Car down faster as well as there is less rotational Mass.
It will also like be a nit tricky to Get smooth engagement out of such a light flywheel without feather the clutch out of the hole at a higher RPM.
The only other option is the True JDM Mazdaspeed Flywheel which is said to be about 18Lbs....And this is not the one in the MSP.
THe One in the MSP is the Same as the OEM P5 one.
So.....Which would you run?
- Stock (? lbs.)
- Fidanza (7.5lbs.)
- True JDM Mazdaspeed (18lbs.)
