Programing Keyless entry remotes?
NoFear1911
2013 MazdaSpeed 3, 1990 Mazda Miata
ok i just got a 07 3i touring and it has the keyless entry but the dealer said when they got it didnt come with the remotes so i was gana buy some off ebay and was wondering how do i go about programing them with my car?
Here's some info from the other mazda3 forum which was taken from the mazda6 forum, lol.
Hope it helps.
Yes, this does work and I actually used it to program a 3rd remote for my Mazda3i (with power door locks). 8)
*NOTE*
Have all the remotes that you are going to be using, maximum of 3, with you when you do this programming as all of them have to be reprogrammed into memory.
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
